Estudio 3511/4511
  • banno
    Estudio 3511/4511
    Hi all
    I have 2 machines not working properly. The 4511 reports Power Failure even though it boots up fine.
    The 3511 reports a service required but I have tried to get the error code by pressing clear and 8 together but nothing happens. Can anyone please advise
    regards
    Mick
  • copytechman
    • Nov 2008
    • 943
    Press FC key 2x, to clear the power failure message (power was interupted to the machine without a proper shutdown) and on the other machine, c + 8 only works for jam codes and service call errors, what service is it asking for?
    Regards!
    A.
    • banno
      Regards!
      A.
      Thanks.
      I have just the service icon flashing and nothing else
      regards
      Mick
      • emujo
        • Jun 2009
        • 3009
        not sure what you mean by "icon is flashing". 08/253 will show you the last 30 or so service/jam error codes by date and configuration. What is the last "C" code you see here?
        • banno
          Thanks for your help. The error code is F100. Is it serious
          • emujo
            • Jun 2009
            • 3009
            Only if you want to copy/scan/print or fax!!!! Bad HDD. You'll need to replace the HDD and re-load system firmware. I hope your next post is not "how do I do this, and can you send me the firmware?" If you don't know how this is accomplished, get a qualified Toshiba tech involved, probably will run you $150 for the HDD and 1 hour of labor. EMujo
            • fourl6
              • Nov 2008
              • 94
              It says Power Failure when it isnt shutdown properly, to turn off a 3511 / 4511 press
              1 User Functions
              2 User (Tab)
              3 Shutdown
              not shutting down properly can wreck hard drives (like your other machine)
              • gfady1
                • 16
                Hi all
                i have 2 problems with my toshiba 4511 and i need someone help
                FIRST: when i open my toshiba i find language (svenska ) and i can't change it from the language menu as there is no other language .. and when i went to the settings 08-220 i can't change No. 5 language to any other language (when i change to No. 1 and restart the machince i find is changed automatically to No. 5 again)
                SECOND: when i give a print order from the computer using any connection (USB , Parallel or Network) the data led keeps blinking but no printing is there and even when i go to job status i find no orders there,, and the copier can't do any thing till i restart it..
                Noting that all process of coping is working super fine ..
                Can any body help me Please ( i think it's a matter of firmware but i can't get it even throught toshiba agency)
                Fady Gendy
                Gfady1@hotmail.com
