In one Toshiba with 1 month in the client, have about 2k copies, and when the print is in color mode, the black is very dark and makes shadows on text. If the printer is in black mode, the text is fine.
I saw the black developer, decreases the flow. Clean all the machine, everything seems to be ok. but the copy stills the same.
Try to change the codes about the black in color mode, it's better but unresolved.
In annex are one example.
4shared.com - document sharing - download DOC080310-004.pdf
