help on e450 pm
  • CCS
    • 266
    help on e450 pm
    I've got an e450 here in the shop, I'm primarily a Sharp tech, but starting to mess with some of the Toshiba's.
    I'm gonna go through this machine and do a full PM. I have s-handbook on cd, but thought I would ask :
    My question is what all 05 and 08 sims do I need to do after PM ? Thanks
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Ok lets make this difficult....
    6 + start button while turning on
    2 start
    scroll through and reset counter on stuff that was replaced.
    when done hit the return button to the main screen(when you did the 6+ start)
    press 1 hit start this will set up the developer (provided you replaced it),
    then shut off when done.
    0&8 while turning on
    252 start
    0 enter
    turn off and then on.
    check copy quality and alignment.
    if it is good then you are basically done.
    I am not going over everything that needs to be replaced as I am presuming you ordered a drum and dev kit and possible a fuser kit along with any feed roller/adf kits that were needed and you know how to clean optics and the rest of the machine.
    This is the quick pm procedure that I do if I do not have the time to do a full and complete (promaster) pm. There are alot of other things to check, firmware level and tray alignment and such that may or may not be needed.
    • CCS
      • 266
      thanks... yes I have new drum, all feed roller kits, and all pm kits
