about Linux default Login&password?
  • npapa
    Guest replied
    Try to login to linux with one of the following username/password combos:
    root/secret
    icp/secret
    Nick
  • jflegal
    Guest replied
    McKinley is correct. The default password should be "12345".
    Best of luck!
  • mckinley
    replied
    if 12345 doesn't work try sysadm
    remember to spell it exactly as above.
  • westfox
    started a topic about Linux default Login&password?
    reinstall step:
    step 1 run the partition cd (gl1020part cd).it's ok!
    step 2 run the recovery cd (gl1020rec cd).it's ok!
    step 3 set up printer settings (ip address).it's ok!
    but,I don't known the Linux default "lodal Localhost login: " & "password: " . I can't login the computer of e-studio35!
    Can you help me?
    Thanks!
