Toshiba e studio 203 , toner sign
  • ZULFIQAR
    • Sep 2009
    • 3
    [Misc] Toshiba e studio 203 , toner sign
    Hello friends ,
    i am facing a problem in toshiba e studio 203 that when i
    replaced new toner , toner sign is still appeared , how will this removed ?
    Please help me if any one has experienced this problem .
    I will be most thankfull .
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    is it "replace toner" or "toner low"? if it is toner low then user function>user>general>toner low reset.
    • ToshibaTech
      • Apr 2007
      • 580
      It's pretty common on this series to forget to pull the little paper seal out. If you have forgotten this then the toner cartg. is probably ruined. Usually if it is broken you can pull the toner out and the little coupling on the back will just pull right off. If this happens then you need a new toner cartridge.
      Oh, is this a 203L or a 203SD desktop? If it's the desktop machine make sure you got all the tape off of it and that it's a T2021.
      I will not give you service manuals or firmware.
