Toshiba E-352 Cannot start application.
  • Scijohn23
    • Sep 2009
    • 91
    Hello all,
    I am working on a Toshiba E-studio 352. It is giving me a hard drive issue. First I reloaded the Hard drive thinking that this should solve my problem, yea right! So after hard drive is reloaded I am still getting the message on the op panel "can not start aplication". So now I remove a hard drive out of another E-352 that I know works and install it into this machine. Still the same message... I can't get to any of the service modes or anything.
    Suggestions welcomed.
    Thanks in advance.
  • ivovb
    • 695
    Try to reload the firmware completely. Not only the HDD part.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • jamesyboy
      toner monkey
      • Jul 2010
      • 188
      yes sounds hdd
      hold down c/3 select option 3 press print then reload firmware and format hdd
      only do c/3 if you have the firware otherwise it could be a toaster
      • emujo
        • Jun 2009
        • 3009
        Had this a few times..2 way you might correct it...1st if your are at the latest version (352 I think) take the MFP back down to ver 300 (full install) and then back to latest. 2nd use the recovery jig to set the MFP back to factory then reload latest f/w (full install). That message means that the OS is corrupt and can't load. Emujo
        • Scijohn23
          • Sep 2009
          • 91
          Thank you for the help, Machine is fixed.
          • emujo
            • Jun 2009
            • 3009
            Don't want to pat myself on the back yet...what was the fix? Emujo
            • Scijohn23
              • Sep 2009
              • 91
              Ended up being the Firmware, currupted somehow I dont know but reloading it worked. Then still had to reload HDD, but checked it first with a HDD from my other machine that I know was good and it fired up fine. And once the original HDD was restored worked as well, Thanks.
              • firewind
                Re: Toshiba E-352 can not find HDD data
                hello,
                Thank you very much in advance your interests
                I turn on the machine does not perform any operation,Can not find HDD writes data on the screen.What I will do , How do I install the new version.Where I find program.
                best regards
                d.korkmaz@hotmail.co.uk
