Holepunch Error CB80
  • AVux07
    • Oct 2007
    • 57
    This code has appeared twice before on an es850 witin the last 6 months. Both time replaceing the PWB-A Bd on the hole punch fixed it. Today it did it again so I took off the hole punch till I can get a replacement Bd.. The definition of the code is:
    Backup RAM data abnormality:1) Abnormality of checksum value on the finisher controller PC board is detected when the power is turned ON. 2) Abnormality of checksum value on the punch controller PC board is detected when the power is turned
    Also,when I rebooted the machine, I had a F105 code that reformatting the HDD took care of.
    Thanks,
    Al
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Al post which finisher and hole punch w/firmware. I think there was an issue with one of these combo's.
    • AVux07
      • Oct 2007
      • 57
      I replaced the hole punch bd. two weeks ago and swapped the hole punch unit with a hole punch unit on an identical machine next to it. The different hole punch unit has now blown it's control bd. so the problem is somewhere in the connected finisher. Both machines have identical firmware versions. Has anyone had this type of problem?
      Finisher - MJ1028
      Hole Punch - MJ6003
      Copier - es850
