e-studio 280 drawers not function
  • BATA
    • Mar 2012
    • 27
    hello, in e-studio 280 when you select any drawer , you hear strong noise and copier make add paper
    though its full , manual bypass is the only working, can you send me solution or service page of the paper feed section , you are so good
  • JustManuals
    • Jan 2006
    • 9838
    Re: e-studio 280 drawers not function
    Paul@justmanuals.com
    • Gregg
      Paper lift motor.
      P.M me if you need one.
      • jamesyboy
        toner monkey
        • Jul 2010
        • 188
        check gears in lift drive gear box sometimes a stud snaps and you can fix with a self tapping screw
        • TheOwl
          • Nov 2008
          • 1732
          Yeah, definately the tray lift motors. They are very common to go in these machines and others from Toshiba.
          Pull the rear cover off and you should be able to see a white box down in the bottom left. This is the motor and gearbox for the paper tray lift.
          • didi2005
            • May 2011
            • 401
            Normally only the lift motor harness problem, where the black color wire easily broken, resolder/modify it, it should run fine...
            Or, gear/casing broken...
            • toantam
              • 63
              Dear friend!
              You can open the rear side of the machine, you can see paper lift motor at below
              Take it out and check the gear in side.
              Good luck.
              • didi2005
                • May 2011
                • 401
                Today only i encountered similar issue on e232, gears & motor ok, but the casing that holding the small gear is broken ~~~
