After I had rebuilt the fusing drive section this code appeared. Checked all connections and harnesses specified in the manual as well as test mode. No fried boards.
Tried the one way gear both directions. No change. I am very confidant my drive system is perfect though.
Very confusing, my task did not require me to screw with the secondary transfer
Though I noticed it said at the bottem to check mechanical actuators and sensors etc.
....which??
....which??
