Toshiba 556 radf double sided copy jams
  • simonsays
    • Aug 2013
    • 95
    Ive run in to a real headache with a RADF problem. Feeds fine single sided but when you use the duplex copy after it goes to turn around the paper to scan the second side it jams at the gate i removed the rear cover to make sure the solenoid is working and it is. The gate dont seem to be broken either but the paper seems to stop right at the reverse exit gate anyone run into this before could sure use some insight or direction on this
  • Aethanite
    Service Technician
    • Oct 2012
    • 42
    Re: Toshiba 556 radf double sided copy jams
    Hi there.
    I know you mentioned the solenoid, how did you test it was working? By just observing it in action or did you do an 03 test? Is the spring still located in the correct position? Has the spring lost any of its flex? Make sure the solenoid is in the correct position being sure to align the edge of the bracket with the markoff line of the frame.
    Also make sure that on the front side of the radf, under the original tray, coming in contact with the exit flap is a little metal plate. It can sometimes get deformed and apply too much/too little pressure and can cause paper to run into the gate when duplexing due to this.
    Thanks!
    • simonsays
      • Aug 2013
      • 95
      Originally posted by Aethanite
      Hi there.
      Thanks!
      Ill check thats thanks for the help
      • Mad_Coachman
        • 99
        Check this return spring(item 20). I have seen this get weak and/or deformed.
        • simonsays
          • Aug 2013
          • 95
          I did notice this spring it looked ok but how would you no if if was weak
          • Mad_Coachman
            • 99
            When you pull that gate you see if it snaps back to it's original position quickly and all the way.
            • simonsays
              • Aug 2013
              • 95
              ok i will check it out and let you no
              • simonsays
                • Aug 2013
                • 95
                yes it was the spring thanks so much
                • simonsays
                  • Aug 2013
                  • 95
                  Yes mr coachman you got it right i used a piece of tape temporarally to give more presure worked like a charm now i have to get one ordered thats nothing you would have would it i hate putting in a emergency order for a 30 cent part. if so im a full line dealer i could get you or trade you any trhing you needed
                  • Aethanite
                    Service Technician
                    • Oct 2012
                    • 42
                    I may not have worded myself correctly sorry
                    • simonsays
                      • Aug 2013
                      • 95
                      no thats alright it was the spring was not appling enough pressure
