toshiba c3500 says jam
  • poekeypop
    • Feb 2014
    • 16
    [Jamming] toshiba c3500 says jam
    machine shows jam after running, none found, will not reset unless u shut power off/on, can run again, then shows jam,again. i was told maybe power problem? part of a package i service.
  • JustManuals
    • Jan 2006
    • 9838
    Re: toshiba c3500 says jam
    Paul@justmanuals.com
    • Boogotshot
      • 61
      Sounds like a sensor is flaking out, have you tried doing input/output checks on the machine? Toshiba should show you approximately which sensor it is in most cases.
      sigpic No! we never do that with the copier.
      • stockman123
        • 128
        I would start by looking for a piece of ripped paper holding down a switch or a access door not seated properly where does it say the jam is
        • canonbundy
          • Jun 2012
          • 607
          I am guessing an E030 Jam. Check connector to fuser exit sensor and the other end behind the r/h fuser cover, these connectors will seperate from constantly opening & closing the exit flap to remove jams - when rectified do the maintenance, ie clean any toner build up on the metal guide plate also the Sep Claws & make sure all springs are intact.
