Toshiba Studio 256se periodic maintenance 0088
  • atech
    • Aug 2010
    • 89
    [Error Code] Toshiba Studio 256se periodic maintenance 0088
    How to cancel "Periodic Maintenance 0088" for Toshiba Studio 256SE?
  • arnh79
    • 468
    Re: Toshiba Studio 256se periodic maintenance 0088
    08-9891 set to 0
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • atech
      • Aug 2010
      • 89
      Originally posted by arnh79
      08-9891 set to 0
      Thanks Sir, but it does not work. periodic maintenance 088 still flashing. Its very unfortunate that I do not have a service manual for this model. It seems that 4 digit number codes are required for this model. Is there any other way to make this machine work? I need service program for this model. Do you have the materials Sir? Thanks
      • arnh79
        • 468
        You can also try 08-6190 set to 0. I have run into issues with that series where even setting 9891 and 6190 to 0 the "0088" message wouldn't clear. A f/w upgrade fixed that issue. Unfortunately I don't give out manuals or f/w.
        • drolfe@webmail.co.za
          • Sep 2012
          • 69
          switch of machine then boot up holding start and 6 then press 2 then you can go and reset all the maintenance counts it will show you which ones are over
          • AsankaEkanayake
            Re: Toshiba Studio 256se periodic maintenance 0088 hi.. how to cancel the same error
            hi.. how to cancel the same error code periodic maintenance 0088 in toshiba estudio 255?
