Need Toshiba E-Studio 280 firmware
  • sander76
    • Feb 2015
    • 6
    I got error code F103, does sector check still error on it, change the hard drive now the machine says hdd no data. Please need help with this.
  • bigwul
    • Jun 2014
    • 60
    Re: Need Toshiba E-Studio 280 firmware
    You will need to get hold of the latest FW and re-flash to the HDD.
    • sander76
      • Feb 2015
      • 6
      @bigwul, can you help me to have the firmware for this? thanks
      • bigwul
        • Jun 2014
        • 60
        Unfortunately no - you will have to rely on the possible goodwill of some on here.........
        • sander76
          • Feb 2015
          • 6
          @bigwul, thanks for the suggestion hope someone will help
          • sander76
            • Feb 2015
            • 6
            thanks, the machine's now working, thanks for the help guys.
            • peterxu256
              • Jul 2014
              • 110
              Re:failure to Toshiba E-Studio 280 firmware update
              I need some help about e-studio 280 firmware update. the Screen is Freezed at following stage:
              "Download Storage Update Mode
              Please wait ........ now initialization "
              It never go to next stage even after waiting much longer than 3 minutes, like 30 minutes. Does it need file path? I just put 6 data files in root directory, I may think it would like Ricoh's to create Folder directory path Romdate and subfolder product code, please advice.
              By changing other USB storage keys, simply pop up the message:
              " PLEASE Set Correct USB storage Key"
              Thanks for all for the help.
              • Riyadh hossain
                Re: failure to Toshiba E-Studio 280 firmware update
                your usb flash drive must be 128mb-1gb with Fat format otherwise change hdd
                • peterxu256
                  • Jul 2014
                  • 110
                  I did change HDD, I updated the firmware because of it.
                  I am thinking of USB key problem, 1GB key from the dollar store may not work well. I changed other key, it just popped up the number in series 1.2.3.4.5.6., no context and no version number. And another luck chance was that it popped up the number 1. marked "*HDD data", no version number, I hit the START key, it works fine, updating HDD mass data, no error cod, no failure. but 08-933, 08-934, 08-935 still blank no firmware loaded, So I am thinking, I still need updating ROM.bin, and sysfirm.bin
                  So far I can not print, "Data In" flashing, but never paper come out. Also I cannot access TopAccess web monitor.
                  Thanks for suggestion.
                  • peterxu256
                    • Jul 2014
                    • 110
                    Problem solved, Using small SD card(for Ricoh machine) via USB reader, FAT format is important issue as well as quality of USB flash Drive, must be a brand name.
                    • Riyadh hossain
                      Have any link of firmware of 280?
                      • rapidocument
                        Multibrands Tech
                        • Jul 2012
                        • 381
                        You can get it here (Link)
                        Starpr1nt Manuals, Firmware and Solutions
                        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
                        • Oystercopy
                          • Oct 2009
                          • 580
                          There is a particular procedure when replacing Toshiba drives that must be followed. What another poster said about using a very small (and now hard to find) smaller USB drive is correct on the older series (e-280 series). That's why I still have a working 512mb drive around, but all my older machines have already been updated with the latest 4006 firmware at this date, or traded in by now.
                          Here is the actual procedure I use. Hope it will help someone! (this does not apply to the "6" series and newer Toshibas, like e-256, 456, etc. Only to the older, up to "5" series machines:
                          HDD REPLACEMENT ON A TOSHIBA
                          Installnew drive in rear of copier
                          Poweron machine holding Clear and 3
                          Chooseoption 3, then Start
                          Whenmachine says "Loader Partition Created", power off
                          Thenpower on again with Clear/3
                          Chooseoption 2, then Start
                          Whenmachine says "Format Complete", power off
                          InstallUSB stick in rear right USB slot
                          Powerup holding "4" and "9"
                          Shouldcome up with Firmware List
                          Choosethe HDD UPDATE option only, and deselect others (usually options 1, 3 and 4 getdeselected by pressing those buttons), then press Start.
                          Machineshould start loading about 3 levels of partitions in the drive
                          Whenit says "Update Completed", power off the machine, and remove the USBstick.
                          Powerup holding "0" and "8" and go into Adjust Mode
                          Choose690 and Start to format the drive one final time.
                          Whenyou power off and back on, the machine should come up normally in the Idle(Ready) state
                          Done
                          OC
                          • iddhi
                            Done
                            OC
                            Wher can i get firemware for toshiba estudio 280 please need someone help
