ES 723 completly dead
  • Hansen88
    • 1065
    This machine has no signs of life no fans no noises nothing. I changed the power supply the interlocks and the on off switch. I tried unplugging components nothing working. Anyone have suggestions. Thanks
  • ivovb
    • 695
    Re: ES 723 completly dead
    Do You have voltage output from PSU - 5V, 24V etc.? If Yes go for SYS board.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • buuluu
      • Apr 2014
      • 49
      Hi
      you watch the fan on system board. Does It work? If no, may be your system board is out of order. If no voltage on input of power supple board, you check the CB on unit at wire core.
      • Hansen88
        • 1065
        Thanks for the replies guys. I may not know what the fix is for a while. This machine was a rental at a school and my boss swapped the machine out right away so I have not been able to do any further troubleshooting yet. Eventually when I figure it out I will let you know what the problem was.
