Re: e2550c black stripes
After a week, customer called back saying the problem dissappear...
Check the transfer belt to make sure it's free to rotate, as the bushings seize up on this model.
Check the transfer belt cleaner isn't clogged up / spring popped out of unit ( the auger is a long spring on this model ) , customer's shake the waste box & refit it, it then fills up & the machine doesn't know as there are no sensors & so the EPU's & TBU cleaner get clogged up.
Check that both contacts for the 2nd transfer roller ( inside frame , front & rear roller contacts ) are clean & neither have the packing left attached from setup
Check that the white spacers that sit in the drum unit are in place , they space the LED - Drum ( sometimes they get vacuumed up / tipped into a pile of toner & disappear )
Hopefully a few ideas to try. Cheers.Leave a comment:
Black stripes appear for both copy/print...Visual check on cleaning unit, process unit...Suspect 2nd transfer problem...Any1 encounter b4?
IMG_20150421_143448.jpgTags: None
