Hi I'm after some repair advise regarding this machine
The image is moving and from all trays. Usually the first copy is ok then the others will move by half an inch. Movement is generally variable.
I suspect the registration clutch.
Don't work on these often. Can anyone give some tips on access removal and inspection of the clutch.
Regards john
Sent from my SCH-I545 using Tapatalk
Regards john
