Re: Xerox 550
You need to do the gp4 procedure -serial number syncronization- using sys1 as the pwb with good data.
After that restart machine and check for others errors.
Xerox 550
Re: Xerox 550
If you have same 117-325 error then you need to replace the ess nvm module.
The software is still into this module flash memory but the chip device is bad.
The error 117-325 point to the fact the electronic chip device is malfunctioning.
If another error is pop-up on the screen this can be a good thing.Leave a comment:
Re: Xerox 550
Re: Xerox 550
Where abouts in london are you? Pm me your details and ill give you a callLeave a comment:
Re: Xerox 550
Wat am I going to do cuz, i hav remove d battery and d time hav reset to 2050 and the error still remains and is not shut down again! Pls help me out!Leave a comment:
Re: Xerox 550
Dont remove battery, it will kill the metered pin and reset to default, it also kills the software on the pwb, you will most likely have to purchase a new nvm pwbLeave a comment:
Re: Xerox 550
It is wonderful if you have a previously machine nvm's saving.
If so, try to restore it - dc351 and reload machine software.
If fault still exist after all, then you need to replace the ess nvm pwba module.Leave a comment:
Re: Xerox 550
Can you post a picture of the error on screen?
Is it a black screen with red writing or the normal error screen with the error code in the corner?Leave a comment:
Re: Xerox 550
There is no 117-325 error.
It could be 116-325.
Ess fan errorLeave a comment:
Xerox 550
Pls help me on error 117-325, on Xerox 550 and CE is not coming up and the machine seems hanging?Tags: None
