WC 5875 AltBoot
  • bojans
    • 1313
    WC 5875 AltBoot
    Having problems with this WC5875, hdd is dead. Trying to AltBoot but seems that I need Data cable or Forced_Upgrade file.
    Could anyone share this file with me to do USB Altboot (is it same for 57xx series) and
    what kind of cable is 600T02332 Data cable used for PWS AltBoot
    Thank you
  • Flash
    • 378
    Re: WC 5875 AltBoot
    Did you replace the hard drive? I have had to replace several hard drives on the 58xx series. I have not had any problems with altboot. You just need the dlm. file inside a folder named Altboot on a thumb drive.
    • bojans
      • 1313
      Re: WC 5875 AltBoot
      Tried with couple hdd's and usb pen's. Not starting, that's why I want to try with PWS Altboot.
      Thank you
      • adriansto
        • 2383
        Re: WC 5875 AltBoot
        SBC board problem.
        Take a look at diagnostic led's and read the procedures from edoc.
        • bojans
          • 1313
          Re: WC 5875 AltBoot
          Thank you Adriansto,
          Do you have picture of this Data cable. Or where can I find it online?
          • adriansto
            • 2383
            Re: WC 5875 AltBoot
            I dont know if you will find it online.
            Search by partnumber 600T...
            Named also ScreenHunter_98 Jan. 06 14.07.jpgbackchannel cable.
            • bojans
              • 1313
              Re: WC 5875 AltBoot
              Thank you
              • Flash
                • 378
                Re: WC 5875 AltBoot
                Try a new memory module. Software loads to memory first and then to the hard drive.
                • Exok
                  • Jun 2011
                  • 750
                  Re: WC 5875 AltBoot
                  By the way, you can create your own forced upgrade file. Its an empty file. Create a TXT text file with nothing written in it. Name the file "FORCED_UPGRADE" in all caps just like that. Finally, delete the file extension ".TXT" Place that file inside your Altboot folder along with your DLM file to do a forced altboot.
                  • bojans
                    • 1313
                    Re: WC 5875 AltBoot
                    Thank you Exoc. Tried that but no success.
                    Does anyone have schematic for this Data cable
                    I will take almost one month to arrive after order.
                    • rxpluday
                      • Jun 2017
                      • 6
                      uday from bangalore
                      Hi where should buy this cable help me
                      my email id rangauday@yahoo.co.in
                      may thanks
                      QUOTE=adriansto;546388]I dont know if you will find it online.
                      Named also ScreenHunter_98 Jan. 06 14.07.jpgbackchannel cable.[/QUOTE]
