I have been trying to set up the Scan to Email function for weeks (on and off), to no avail. On the Config report, Email says Installed/Enabled, the SMTP Server IP Address says 192.168.1.107, and the Default Email Address field is definitely showing my valid email address. When I try to scan something to send an email, it keeps printing these email confirmation reports that say Failed, and in my computer browser when I typed in the IP address for our Workcentre 4150, under the Alerts option, it says Error 15-320, saying there is a problem with the SMTP server. I think the problem might have something to do with the Properties setup I did. Under Connectivity, Protocols, and TCP/IP, I have no idea what I SHOULD be putting for the Host Name or the Domain Name. I've tried a few different options for both, but because I have no idea what these are supposed to be, it's likely that this is where my problem is coming from. I'm relatively technically savvy (it's just the terminology here that I'm lost on), and should be able to take instruction on this issue rather easily.
I've gone through the steps on the Xerox website itself, and walked through the details of the user manual that came with the printer. The problem is, nowhere does it define Domain Name or Host Name, and without knowing what these are or should be, I'm still stuck.
I'm at the point where I'm going for blind trial and error, but this is taking a LOT of time, and I'm not having any luck.
Another possible problem is that a friend mentioned that I can't use an email address to send from that is already in use. Is this true, should I just make a generic Hotmail account or something to solve this part of my problem?
