8830 Wideformat.
  • davidj7
    • 1107
    8830 Wideformat.
    Could anyone tell me how to reload the controller N5T software using parallel port.
    The accxess controller is down so i cant use the network option.
    thanks
    a machine is only as good as your tech : source:screwtape ; the scary one
  • TzALbg
    • Dec 2007
    • 111
    Usually N5T NC can be reloaded with 4 floppy disk. Is is bootable version is 4.0
    after that you can upgrade to upper version using WEB PMT.
    • davidj7
      • 1107
      do you have any documenation regarding the installation of v 4.0
      • TzALbg
        • Dec 2007
        • 111
        I'll search it for you, but I need a week at least
        • davidj7
          • 1107
          i can wait no issues and thanks
          • JustManuals
            • Jan 2006
            • 9838
            David;
            Do you need the service manual?
            Paul
            • XeroxTechBrazil
              • Aug 2008
              • 198
              Material Available
              David:
              I have 4 GB of AccXes and 8830 files, including a 15MB zip file called N5T_Disk_Recovery.
              You're welcome to them if you want to pony up the cost of the air mail envelope. Most of the files are too big to attach to an email.
              Is there an EDOC for the 8830?
              You know where to find me.
              • davidj7
                • 1107
                Techbrazil: i do have most of the stuff for 8830 incudling the n5t disk recovery only issue is i donno how to use it.The machine is refurb so i donno what the old ip was.
                From the above threads what i dont have is acexes software 4.0 .i do have the upgrades .
                for now i am going by tzalbg. I have to first install 4.0 via parallel port then go for upgrade.
                • SimmBuzz
                  Re: Material Available
                  Originally posted by XeroxTechBrazil
                  David:
                  I'm changing the HD from a N5T controller and i think i need these files. Could you send this files to me please ? Thanks in advance
                  • adriansto
                    • 2383
                    There is service cd for xerox wide format.
