Docucolor 250 too much magenta
  • savedsoul
    • Jul 2009
    • 49
    Hi, My docucolor 250 is printing a very deep red color instead of magenta.
    What could be the problem?
  • xcopytech
    • Aug 2006
    • 1794
    first check print from diagnostic and if print from diagnostic is ok then check fiery, maybe will need to reload system software on it.
    • savedsoul
      • Jul 2009
      • 49
      Reloaded the Fiery but no change still too much red density. Start up page is also having too much red in the print in the image
      • Milo Wilson
        • 500
        It seems you need to adjust the baseline colors on the 250. You can only do that with PWS.
        • xcopytech
          • Aug 2006
          • 1794
          what about print from diagnostic?
          does it have too much red or print is ok?
          • savedsoul
            • Jul 2009
            • 49
            Thanks guys. I changed the magenta drum and all is fine now.
            • savedsoul
              • Jul 2009
              • 49
              Too much magenta again on DC 250
              The problem has recurred again. It seems to come and go. It seems it was not the drum after all!
              • Eagle
                • Mar 2010
                • 49
                Check mag dev tank bar code number has been entered correctly into m/c diagnostic.
                perform full max-setup with white ref and cal adjustment.
                That should do the job.
                • copytech200X
                  • 264
                  max setup must done correctly and check all consumables life before perfom setup.
                  • savedsoul
                    • Jul 2009
                    • 49
                    Hi, Do I need the PWS or can I do this from the diagnostics on the UI screen?
                    • Eagle
                      • Mar 2010
                      • 49
                      U can do it from the touch screen but dont take me wrong, If u have not got no experience in performing max set-up i suggest u call a technican.
