Phaser 7700
  • sjnordberg
    • Jan 2008
    • 14
    Phaser 7700
    Is there a part number for the vertical path roller (the one that the rubber rollers melt) so that you don't have to order the whole left door?
  • gpoffmachs
    techie
    • Feb 2005
    • 55
    cw
    the 7750 which uses a lot of the same parts is 116175900 exit roller
    i have not matched it up to the 7700 to see if they are the same
    Techie
    • sjnordberg
      • Jan 2008
      • 14
      Thanks for the reply. I will look into that further also.
      • Caffeine
        • 382
        The 7750 and 7760 rollers are both compatible, and so are the DocuColor 1632/2240/3535, as well as ALL WorkCentre models (M24 through the latest 73xx-series)... Only the 7700's melt, so any other roller is safe.
