i have personally never done it on a workcentre76xx family,i have only performed this on dc12 and you need a pws(its a MUST)in dc250 you will
Enter UI Diagnostic mode (see Accessing UI Diagnostics).
Select Adjustment/Others.
Select Machine ID/Billing Data Settings.
Select a PWB with the correct data.
Select Start.
Enter the correct serial number in the Serial Number screen and then select Confirm.
i hope this helps,and gives u ideas on where to look at,note that Diagnostic for dc250 and workcentre are very diffrent,so u have to get that series Diagnostic software.
Select Start.
i have a fully loaded pws,if you are in africa then we can see how to go about it,if not then kindly send me mail in my email(maich4s@yahoo.com)then i can give you contacts where to buy the softwares and new updated pws(most preffered)
