Phaser 7500 "accumulator belt home position took too long" message
  • axyun
    • Aug 2007
    • 1323
    Have done only a few calls on this series. I am doing this call Monday and I would guess most likely problem is either accumulator belt patch, home position sensor or belt motor. Also is this more likely to occur as waste cartridge is close to full. Any help is very much appreciated. Frank/ActionPhotocopy
  • Flash
    • 378
    Re: Phaser 7500 "accumulator belt home position took too long" message
    It is most likely a dirty patch on the transfer belt or the patch is coming off. I had to replace a belt for that a couple of weeks ago.
    • axyun
      • Aug 2007
      • 1323
      Thank you Flash. Frank
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • axyun
          • Aug 2007
          • 1323
          Removed IBT Belt and cleaned silver patch and home position sensor. Cleaned blade on belt cleaner uni. Machine working again. Frank
