DC2240 006-383
  • Tinochka
    • Jul 2012
    • 127
    [Error Code] DC2240 006-383
    Hello everybody.
    I have a Xerox DC2240 with error 006-383. It starts up ok. But when I try to print or make a copy the 006-383 error message is displayed.
    From diagnostic I try to start ros motor (dc330 006-031) it operates. Anybody faced the same problem or can look at the Eureka ?
  • johnner66
    • Mar 2009
    • 265
    Re: DC2240 006-383
    that is cause by the laser unit try on the connector that the pin on laser unit is ok then connect again and try g/l
    • Tinochka
      • Jul 2012
      • 127
      Re: DC2240 006-383
      What does that means
      try g/l
      • bojans
        • 1313
        Re: DC2240 006-383
        Check out connector/wires from laser unit!
        • Tinochka
          • Jul 2012
          • 127
          Re: DC2240 006-383
          ok thank you
          • Tinochka
            • Jul 2012
            • 127
            Re: DC2240 006-383
            Today I replaced the Ros assy from another printer, and the error disappeared. So the cause is in the Ros. Does anybody have an experience to fix the Ros?
            Many thanks
