DOCUCOLOR 260
  • Piper
    • Apr 2011
    • 75
    DOCUCOLOR 260
    Xerox Docucolor 260 failing to feed from Bypass Tray ( Tray 5 ). It gives paper jam message on UI and fault code 075-100.
    Even a new Bypass Feeder assembly (Tray 5 ) gives same fault. Manual is leading to replacement of MCU or/and IOT.
    Can anything else be done to correct this fault.
  • adriansto
    • 2383
    Re: DOCUCOLOR 260
    Reseat the flat cable that connect iot and mcu boards.
    You may use good quality contact cleaner spray
