PSW can't detect machine
  • ck1
    • 485
    my laptop didn't have serial port , so can use USB 2 serial cable ? why i can detect the DCC 400 ? thanks.
  • xcopytech
    • Aug 2006
    • 1792
    some xerox machines will not work with usb to serial converter.
    do not know why, just on xerox GSN web site have that explanation.
    Xerox provide to their techs laptops with serail and parallel port.
    • ck1
      • 485
      so mean some machine must use serial port and can't use USB converter ?
      so have the parallel also can use ?
      • xcopytech
        • Aug 2006
        • 1792
        xerox receive a lot of complaint about usb to serial and usb to parallel converters, so xerox suggest to tech to use laptops with serial and parallel port.
        It could work, but depends of laptop and converter brand, etc...
        Have you set serial port number to COM port 1?
        • ck1
          • 485
          but now new laptop more haven't serial or parallel port .i will try change the com to 1 and see . you mean use the parallel port also can for PWS ?
          • xcopytech
            • Aug 2006
            • 1792
            change to com1, will not work if any other com is selected.
            yes if you use usb to parallel convertor it should work with xerox software.
            if you have to use lpt port for some xerox aplications you can use usb to parallel converter. but set that port is EPC nad LPT1.
            • hoba2007
              • Jun 2008
              • 34
              i am need psw tool program for xerox c321, c401
              please
              i have copier stoped working because i didn't have psw tool program
              please can any body send me it and its installtion password and login password
              my email
              ehabrashed@yahoo.com
              hoba2007_eng@hotmail.com
              thanks to every one
              bye
              • hoba2007
                • Jun 2008
                • 34
                please
                my email
                thanks to every one
                bye
