Paper jam problem with xerox 5645
  • livewire
    replied
    Re: Paper jam problem with xerox 5645
    When you clear the jam, delete all print jobs.
    Is the machine ready for work?
  • Enzo
    replied
    Originally posted by Lee2475
    Give me what codes you have and I can have a look on searchlite I've never had a problem with the sensors on the registration before only the one down the very bottom of the left side, does this do it every copy? You haven't got any codes for hvps? As I've had the same thing and it's been that, soon as it tries to put the image on the drum it faults out the paper stops about there, just a thought.
    Only thing to do it run component control and see if the sensors switch and the rollers turn under abit of load.
    Now I do not remember the code number but I have the service manual and it indicates a problem with the sensors. I've already tried to run a check on the components, but it was positive
  • Enzo
    replied
    Originally posted by livewire
    Try to make copy from bypass.
    The sheet from bypass will not start!
  • livewire
    replied
  • Lee2475
    replied
  • Enzo
    replied
    yes, friend! each tray to give the same problem!
    My fault history indicates only a problem with the paper sensors. But I have also excluded this problem as I have also changed the entire Group!
  • Lee2475
    replied
    Also give me the fault history if your sure its not catching on anything in the paper path.
  • Lee2475
    replied
    looks like its catching to me looking at the top of the paper, Have yot tried it from another paper tray?
  • Enzo
    started a topic Paper jam problem with xerox 5645
    hello friends. I have a paper jam problem with my xerox 5645.
    I enclose pictures of the problem.
    The paper is jammed in the area1.
    A technician told me that the problem is caused by the clutch (CL08-070).
    I changed it and the problem is solved. At first, the paper is still jammed, but after a little time the machine worked again.
    After 30 thousand copies, the problem has come back!
    Now I ask you ... is again the clutch? The clutch that I bought is new, not used!
    It may have broken yet? Is there some other reason? Thanks so much.
