Good day, run a lot of 12x18 from bypass tray on 7775, with fiery. the alignment when i try to double sided print is horrible being off as far as 12-18 points vertical and horizontal. i know the 700 has a way to fix alignment from the touch screen, is there anyway to fix this with the 7775? any help would be greatly appreciated as even when the duplex feature is used and align front and back images is used from the fiery settings it does the same thing. thanks
