good day gents, just replaced my esspwb on my 700, got past a few errors, cleared them up, now whenever i try to print i am getting 010-321. i can hear the machine start to try print, but jams and this comes up. i took fuser out, changed, still same error, i have read somewhere that resetting NVM 744-350 to 0 works on the xerox 250, but don't want to try it on this machine as i am not sure it's the same nvm for the 700. any suggestions? thanks
xerox 700 fault 010-321
Tags: None
Re: xerox 700 fault 010-321
IF you are going to repair these type of machine, then you need the service manual. If you had this from day1 you would have been up and running long time ago.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
I agree, but most people that come to this forum are not technicians, mainly owners of small shops that try to maintain their own machines. Most Xerox machines have no hard copy service manuals. A PWS laptop with edoc service documentation is cost prohibitive for most owners/operators with only one machine.Comment
Fly me out to the Bahamas and I'll fix your machine...lol I'll even upgrade to 700i and get it running perfectly.Comment
Hi Milo, long time. I worked on Xerox machines in Nassua Bahamas ,two trips, two weeks at a time. Hard to get parts shipped on a boat from Florida. Atlantis was fun to work at, but driving on the left side was like when I was in England, hard to get used to. The people are real pleasant to work with. You would really like it.Comment
hell if you serious i would, need this repaired asap. need software on the 700, my software version is saying 0.0.0.0 after i did the switch of board and cleared everything.Comment
I agree, but most people that come to this forum are not technicians, mainly owners of small shops that try to maintain their own machines. Most Xerox machines have no hard copy service manuals. A PWS laptop with edoc service documentation is cost prohibitive for most owners/operators with only one machine.Last edited by subaro; 03-04-2015, 02:01 AM.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
see that, maybe that can help you
http://www.copytechnet.com/forums/xe...010-321-a.html
have a nice day
aclComment
Nip sensor in component control 010-203, sensor in fuser under side cover. Rotating disk type actuator, shaft can be turned through cover by by rotating shaft with flat blade screwdriver, can't remember if ths can be done in place, check on removed fuser first.
Fuser drive - 010-001
fuser nip sensor goes through main drawer connector to pj 405 on mcu, drive motor to mcu pj 412
Please take care around the fuser as mains power is present.Comment
