xerox m35-start button
  • savi0r
    • Sep 2010
    • 363
    Hi all. Does anyone know if the start button from the xerox m35 can be ordered separately? or does it fit from another machine?
  • tasosGR
    • Jun 2014
    • 23
    Re: xerox m35-start button
    You can use one from a st or dc 460 / 470 / 480, Buttons are same with M35.
    If you have not any machine, You can replace one from the button (? or *) from the same keyboard.
    Start have 2 buttons
    Good luck!!!
    • savi0r
      • Sep 2010
      • 363
      Good luck!!!
      I don't understand the last part,with the ? And * button. Can you be more explicit?
      • adriansto
        • 2387
        Adica ia microintrerupatorul de la butonul steluta sau semnul intrebarii si muta-l in locul celui defect.
        Nu vin microintrerupatoare separat trebuie comandata toata placa la aparatul asta.
        • savi0r
          • Sep 2010
          • 363
          Aaa,nu am nevoie de microintrerupator. Am nevoie de butonul de start,cel de plastic.
          • tasosGR
            • Jun 2014
            • 23
            If you have not any machine, You can replace one from the button (? or *) .These buttons is not very useful, from the same keyboard.
            • adriansto
              • 2387
              It's about green plastic button not microswitch push button.
              • tasosGR
                • Jun 2014
                • 23
                I agree with you, I write for a solution when there is problem (2) micro switch on pwb of the keyboard.
                If there is problem with the green plastic button then must been order a new one.
