Riso RP 3700 D02-532
  • lechimp
    • Jul 2025
    [Error Code] Riso RP 3700 D02-532
    Hello,
    thank you very much for your collected knowledge here in this forum.
    So far, you have already been a great help to me as I have solved several problems by just readin existing entries and trouble shoots. Here now I am stuck and hope for some insights.
    During printing, after approx. 400 pages with a drum that has been used frequently before, suddenly the color became less and less, fading away with each printed sheet. I stopped the printing and created a new master. The color barely went through the master foil. I took the drum out to check and put it back inside. Ever since, there is the error code D02-532 wrong type print cylinder. This problem concerns only this one drum, if I use another drum, it works just fine.
    I am glad for any information I get to solve this! Thank you in advance.
