Yesterday my MZ790U machine started to flash error # T02-401 that could not be cleared with the RESET key / my machine will not print at all.
Full disclosure: about 3 months ago the machine began flashing T02-401 whenever the paper feed tray was empty. It could be cleared easily by putting some paper in the feed tray and pressing Reset. Since then the machine has been running 90% smoothly using the same fix over and over. The only thing was the little green button on the paper feed no longer responded when the paper feed was completely down. It did work, however, when it was at any other position and you needed the feed tray to go down.
But now I'm not sure what to do as I've troubleshooted by turning the machine on and off, removing paper, making sure nothing is blocking or touching the tray, gently opening and closing the input tray, etc. Nothing I seem to do externally helps so I think I am in need of a technician.. but I live in Oslo, Norway.
Any advice, diagnoses, offers to sell parts, etc are all welcomed! Thank you.
