Hey guys,
I've been having a problem lately with the black drum (copy count: 777,534) on my Riso MZ. When I try to make a new master, the machine tells me that the master is stuck in the master disposal box and to remove it, which it isn't, and then that I need to manually remove the master. After a few goes of this, it eventually makes a new master but sometimes the previous master is partly ripped and still stuck to the drum underneath the new master. I've attached a photo of what it looks like when I pull the drum out to remove the master like the machine asks. It's happening on both sides of the MZ and only with my black drum. I recently replaced the 'master disposal belts' (rubber bands) on both sides of the machine thinking that it might be a problem with those but that hasn't seemed to help. Somebody suggested in another thread for a similar problem to try cleaning the clamp plate and clamps and to lubricate the pivot points, which I did, but that hasn't seemed to help either. I've also noticed that the black ink is causing the masters to yellow quite a lot, which I hadn't noticed before unless the masters were left on the drum for quite a long time. I always use OEM inks and masters too. Does anyone have any ideas of what the problem might be and how to fix it?
Thanks in advance!
Dan
Thanks in advance!
Dan
