Hi guyz
I have a duplicate do m300, the machine prints double on paper, I changed the ink but still problem persist, when I try to remove the drum out it can't come out, you find the pressure roller is up resist the drum to come out even if the drum is in home position. So if I want to remove the drum out I have to open the machine back and pull down the pressure roller tension spring. Please any one with solutions help
