Canon 5070
  • tecaldryn
    • 22
    Canon 5070
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Go into Additional Functions>Common Settings>Limited Functions Mode and select "OFF" and reboot the machine with the main switch.
    There must have been an error malfunction that caused this.
    • tecaldryn
      • 22
      done the way you said, was active all functions.
      thanks! cheers ...
      • tecaldryn
        • 22
        HI.
        Screwtape, WAS EVEN ON THE SERVICE LIMITED. BUT THAT ONLY
        After I had hung FUNCTIONS, NOT A TRAY OUTPUT
        Correctly place, NOW CHECK THE SENSORS
        POSITION, IS GOOD. WHAT IS A VERSION OF THIS MACHINE IS NOT COMPATIBLE WITH THE FINISHED VERSION? MN-CONT E 1.31
        LUCK 07:01
        • tecaldryn
          • 22
          HI.
          POSITION, IS GOOD. WHAT IS A VERSION OF THIS MACHINE IS NOT COMPATIBLE WITH THE FINISHED VERSION? MN-CONT 31.31
          LUCK 07:01
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Originally posted by tecaldryn
            HI.
            LUCK 07:01
            I don't understand what you referring too?
            • wannaskyline
              Re: Canon 5070
              This worked for me on an ir5050. Also made me understand that is something is blocking the output trays it goes into this mode as a safety so that it doesn't break itself. The end users failed to tell me that the machine had asked to go into limited mode...
