I just bought a New Out Of Box Oki B4350 it came with Europe AC Cord Went through the setup Used a new universal power adapter (using the unit in the US) Pluged it in nothing happened. No lights No sound any ideas
Oki B4350 no power at all
Re: Oki B4350 no power at all
I don't what kind of "universal power adapter" you've got ... but did you really think that a 230vac 50Hz printer could work on 120vac 60Hz? Half of the voltage?
This isn't an incandescent light bulb. It's got a lot more complex operations going on inside. =^..^=Last edited by blackcat4866; 05-19-2012, 02:23 PM.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Paul
pcs: ... and don't try connecting it to a 220 volt US outlet either. In Europe it's 230vac 50 Hz single phase. In the US it's 220vac 60 Hz two phase. If you want to think of the alternating current as sine waves, the European one is a single waveform that peaks at 230 volts, and the US one is two separate waveforms that peak at 120 volts. Suffice it to say that it's not the same. =^..^=Last edited by blackcat4866; 05-20-2012, 03:58 AM.If you'd like a serious answer to your request:
