Spare Parts name!
  • Abimotek
    • Feb 2015
    • 60
    [Misc] Spare Parts name!
    Pls help me name called, spare part is found common in all deskjet printers, a straight tiny nylon and long between carriage. Just like Encoder disk is round, while this is long in shape,with strip lines Pls name for iti wait replyThanks
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: Spare Parts name!
    A bit more info would be nice.....
    It sounds like it might be the "encoder strip" that is the name of it ?
    You may like to take a photo an paste it to the forum.
      • 22599
      Yeah, lets see a picture. =^..^=
      • allan
        RTFM!!
        • 5429
        Its the encoder strip?
        Whatever
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          how about a Make and Model???????????????????????????????????????
          Mystic Crystal Revelations
            • 22599
            Based on almost nothing, I would have to guess that allan is correct. The encoder strip is a way for the controller board to monitor the movement of the carriage, for example, is it moving at the correct speed? Is it stuck/not moving? There is a photosensor that counts the passage of those microscopic lines. If you get ink buildup on encoder strip the printer will error out with a carriage movement error. =^..^=
