Brother HL-5150D drum unit "salvaging"
  • gloa
    After changing the drum and resetting the drum counter, the printer output was "spotty" (because of the fusing unit as I learned later). I tried another new drum (a Brother unit rebuilt by Xerox) and inadvertently reset again the drum counter. As far as I know, this process blows a fuse inside the drum.
    Is there a way to salvage the second, practically brand new drum unit when the present drum will "wear out"?
  • Techtime
    You can use the other drum unit without a problem. Just go through the same reset process when installing the replacement drum unit. The machine reset a internal counter in the machine itself.
    • gloa
      Thank you Techtime, I'm looking forward using your hint in due time.
      • Aimeelin
        Re: Brother HL-5150D drum unit "salvaging"
        Maybe the problem is the drivers, so you can reinstall the drivers for this software, and you can get it from here: Brother HL-5150D Printer Drivers Download.
