Brother HL-2040
  • GHAZALS
    • Sep 2024
    Brother HL-2040
    Sir, I have replaced new Toner Cartridge in this machine, but still the toner indication is on & the mc in working, pls advise
  • LaserSharp
    • Sep 2007
    • 94
    Is the unit asking for toner...or a drum unit?
    • GHAZALS
      It is TONER
      • raym
        • Apr 2005
        • 62
        try this. power off and open front cover. press and hold "go" while powering on. once the three led's are lit, release "go" button. now press "go" two times. led's should light solid. once lit solid, press "go" five more times. close cover and toner end should be reset.
        hth,
        ray
        • Gulfboy
          HL-2040 Toner reset fix
          I too was having the tone light blinking. I tried the fix suggested, unfortunately now the printer will not print. I tried factory reset and it doesn't seem to work.
          Now with the power on the ready light is on steady and no toner light, but the fan runs all the time and it will not print. Was working OK except for the tone light before.
          Any thoughts on how to get the printer back to factory defaults?
          • bojans
            • 1309
            Return the white gear from left side to starting position...
            • Gulfboy
              Brother HL-2040
              Got pic of gear and I will look for that, but this happened by just pushing GO button?
              I'll check it. Thanks
              Gulfboy
              • JustManuals
                • Jan 2006
                • 9931
                This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
                • Gulfboy
                  Brother HL-2040 Problem
                  Gulfboy
                  Something else I noticed, when power is turned on unit doesn't turn on, just the fan.
                  Usually, the unit runs for a few seconds and then shuts down. Is there a fuse on the heater unit? Tried Raym reset, but after holding GO and powering on all lights come on, release GO lights go out, hit GO twice nothing is lit except the Ready lite.
                  Gulfboy
                  • bojans
                    • 1309
                    [ATTACH=CONFIG]6536[/ATTACH]
                    This is for resetting toner.
                    Gulfboy I don't know what's solution to your problem.
                    • E Winter
                      Yeah, just reset the toner detection lever - it's a white thingy located at one side of the cartridge. You'll need to turn the dev-roller backwards while forcing the lever a bit so it moves about 45 degrees.
                      • good
                        • Sep 2012
                        • 51
                        Re: Brother HL-2040
                        If resetting doesn't help then sometimes the toner is the problem.
                        Did you replace it with a generic or oem toner?
                        Sometimes generic toner causes this problem.
