Remote Restart JetDirect Laserjets?
  • cjmac
    Hi there,
    Anyone know if it's possible to send some kind of (SNMP? PJL? RCFG?) "reboot" command to a JetDirect server? I've noticed that when certain errors occur, the embedded web server doesn't respond, but telnet server does.
    Some of my printers are 10 mins+ walk away, and some are an hour's drive away (and my users aren't about to do it). I know the option is there in Web JetAdmin, but I'm not allowed to use that here (long story).
    Anyone know how to manually do it? Hope I'm being clear.
  • nmfaxman
    • 1702
    I haven't dealt with the newer JD cards but I would think a user could unplug the card and count to 10 to plug it back in.
    If they won't respond electronically, a hard reboot would at least save you a trip to do the same thing.
    Just food for thought.
    • cjmac
      Hey, I appreciate the response. Not allowed to ask users to touch hardware (they're not supposed to at all) - and it's not the card, it's the actual printer that needs restarting.
      I haven't dealt with the newer JD cards either - all mine are 610/615/620
      • JustManuals
        • Jan 2006
        • 9838
        Well you DO know that the 615n card has been recalled by HP right?
        Paul
        • cjmac
          Paul
          I do now. Hmmm. Got a lot of them out there. Any problems with the 620s?
          • JustManuals
            • Jan 2006
            • 9838
            None that I've heard of. The 615 problem was a while ago. They were giving replacements but I think that's long over. You should do a search for the 615 on the HP site. I have the HP Service Note on this problem.
            Here is the link to download it. The link will be valid for 200 downloads and 14 days.
            YouSendIt - Send large files - transfer delivery - FTP Replacement
            HtH
            Paul@justmanuals.com
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              The 615 card is so bad it can cause problems by just being in the machine even if you are not using it. When I have an HP that will do any number of stupid things, and has a 615 card, I upgrade them to a 620 and problem solved.
