HP Color LaserJet MFP M476dw
  • Lance15
    replied
    Re: HP Color LaserJet MFP M476dw
    The DC Controller fixed the pick issue I was having on my M276. Sorry for hijacking the thread. Figured it might be useful.
  • Lance15
    replied
    Went back and tried another roller. No change. DC Controller delivered yesterday.
  • spree
    replied
    Originally posted by theengel
    I wonder how many machines got thrown away as "unfixable" when techs had those rollers and didn't realize it. I myself replaced a pick-up motor and a DC controller on a machine because of them.
    My experience is that brand new genuine HP pick-up rollers are bad sometimes.
  • Lance15
    replied
    We've got an M276 doing this exact thing. Roller and fuser was replaced and was going to replace the DC controller as well. Think we'll go back and try a different roller. We only use OEM rollers.
  • theengel
    replied
  • aAandy
    replied
    These use those little PacMan rollers (that's what I heard another tech calling them, anyway).
    There was a batch of bad ones going around. I think they might have actually been OEM, but I'm not sure. I just know I had a problem machine that I could not fix. Finally, I replaced the PU roller again, and it worked. I took the old roller, and compared it to the new. One was a hair bigger. Actually, I compared the rubber part of the roller. And I know there are a bunch of there out there--the rubber is too thin, making the diameter of the roller too small, making it jam... sometimes every single sheet, sometimes intermittently, sometimes in certain feed situations (like the one you described).
    excellent, just what i was looking for - i'll add some tape under the rubber to increase the diameter
    that fixed it - added double sided tape under the feed rubber
    thank you!
  • theengel
    replied
  • tech28
    replied
    Possible fuser, machine does not recognize the 1st page exiting. So, it jams on second page all the time. Basic principles in copying process. If it occurred intermittently, on multiple prints, you would have to go in different direction, but on second print only, that tells you as 1st paper exits, machine does not see it exiting, JAM. Good luck.
  • aAandy
    replied
    hello?? anybody?? 79 views while more recent threads have received 200+ views
  • aAandy
    started a topic [Jamming] HP Color LaserJet MFP M476dw
    hello everyone
    tray 2 (cassette) single prints, she feeds perfectly every time - multiple pages and it jams 2nd page every time
    new feed & sep rollers fitted, everything cleaned, firmware updated, checked paper size (A4) & type (plain) were correct - 2nd page feeds but falls about 1mm short of the registration rollers
    interestingly, if i set tray 2 paper size to "any" it prints the first page, then calls "misprint" and goes into cleaning (i assume a timing issue, likely due to paper not making it to the registration rollers on the 2nd page)
    the machine has done 43k prints
    any ideas?
    thanks in advance
