Scanner 4500 (HP Designjet) hard drive failure
  • pbrooks259
    • Jun 2017
    • 162
    Hi, if I have hard drive failure on an HP Designjet 4500 Scanner panel PC, I do this, right?:
    1. Install replacement formatted hard drive. And
    2. Run recovery DVD.
    This should take care of it, right?
    Paul
  • Kiran Otter
    • Dec 2013
    • 1114
    Re: Scanner 4500 (HP Designjet) hard drive failure
    Correct.
    I recommend getting a PIDE to M.2 SSD adapter and using a SSD. Makes it a bit faster.
    Kiran
    • pbrooks259
      • Jun 2017
      • 162
      Kiran, do you have a link to one of those?
      Thanks very much.
      Paul
      • Kiran Otter
        • Dec 2013
        • 1114
        The adapter is like this: https://smile.amazon.com/44pin-Conve.../dp/B06XC36V63
        Then you can choose a m.2 SSD in the size you want.
        By the way, I'm assuming the drive IS a parallel-IDE 2.5" laptop drive in there. I don't recall them ever getting to SATA drives. If so, replacing it with a SATA SSD is even easier.
        Kiran
        • pbrooks259
          • Jun 2017
          • 162
          OK, I need the caddy and adapter. I cannot just use the adapter alone. Right? Such as this on ebay:
          Find many great new & used options and get the best deals for Hard Drive Laptop Female to 44pin 2.5" IDE Male HDD SDD SATA Adapter Converter at the best online prices at eBay! Free shipping for many products!
          Paul
          • Kiran Otter
            • Dec 2013
            • 1114
            That adapter you linked to might work. It would allow you to use a plain SATA SSD. Not sure how you'd mount that or if it would fit inside correctly. I recommend using one like the one I linked.
            This is another I've used that was a bit nicer. https://smile.amazon.com/gp/product/B017VQT5YW
            Kiran
            • pbrooks259
              • Jun 2017
              • 162
              Kiran, Thanks very much.
              Paul
