Designjet Z6600 24:10 & 79 error
  • theengel
    • Nov 2011
    • 1784
    I've got a designjet 6600 60" that started with a 24:10 error. The light cyan (why does this printer have a light cyan but no cyan) bag had busted. The air tubes had no substantial ink in them, and the ink tubes look filled--no air bubbles in them. I went to the service menu and ran the "recover broken bag". It came up with a 79:04 error. When I took all the ink ctgs out and do the same thing, I get a 26.0.10 error (attached pic).
    Could it be that I HAVE to run the "clean air tubes" and "refill ink tubes"? I don't want to get the dummy ctgs and priming printheads if I don't have to and if it's not going to fix the problem.
    Any help would be appreciated.
  • Kiran Otter
    • Dec 2013
    • 1098
    Re: Designjet Z6600 24:10 & 79 error
    I'd say if you don't see ink in the air lines, or ink coming from both ports on the cartridge, you might have a bad ISS PCB and not an actual broken bag. Especially given the error you're getting trying to attempt the broken bag recovery.
    Kiran
    • Kiran Otter
      • Dec 2013
      • 1098
      I also wanted to mention that a EEROM reset might get you back on track. I fought with a Z6200 over a broken bag situation (that wasn't a broken bag) and finally did a EEROM reset and got around it. It wanted to do a tube priming but since they were already primed, it just sort of went through the motions and nothing really happened.
      Kiran
      • theengel
        • Nov 2011
        • 1784
        Thanks, Kiran. The cyan bag WAS broken. It did leak a little. By the time I'd gotten there, they had already replaced it. So I checked to make sure the new one is good and checked the lines, and everything looked promising. Until I tried the reset.
        • Kiran Otter
          • Dec 2013
          • 1098
          Ah, alright. You don't have to do the air tube cleaning; even if you see a little ink just lie to it and tell it they're clean. The 26.x:01 just means there's a bad contact with an ink cartridge. I find sometimes you have to push the cartridge in, while also pushing the receiver in from the back and sort of grind them together to make a good contact. If it keeps giving that error, you could replace the ISS to cartridge cable. But I would try another cartridge first. Make sure no ink has leaked onto the ISS PCAs or connectors.
          If you can't get by it, try the EEROM reset. The manual actually says the printer will know the tubes have been primed. It didn't on Z6200 I dealt with.
          Kiran
          • theengel
            • Nov 2011
            • 1784
            EEROM took care of it.
