Hey guys long time no see, I've been a bit busy lately. But I finally got another callout and I think I'm basically on top of it but I wanted to check myself just to make sure and reinforce or deter my habits as necessary.
That being said this is fairly straightforward I think, the HP printer that's in the title is what the customer has been using to print checks for a very long time. It has a smear strip along the left edge that's rough to the touch and in my mind that pretty clearly indicates the fuser. They are also looking to replace this device soon as it's a fairly old device and while onsite I mentioned that there's enough unpleasant noise coming from it's guts that needing more work done soon is a strong possibility.
So this boils down to two questions;
1) Am I on track with assuming that the fuser is the likely culprit? (scan of test linked at bottom)
2) Since I'm going to be trying to pitch a Kyocera replacement where do I find out if they can use MICR toner? I hadn't thought of it before but I don't ever remember seeing that listed on the spec pages of various MFPs
Thank you guys in advance for the help\suggestions. I don't know what I'd do without you guys, I so desperately wish I had an experienced tech nearby I could be learning from
Test Page
Test Page
