HP M479fdw torn mylar film on slit glass
  • copyman
    replied
    Re: HP M479fdw torn mylar film on slit glass
    I just had the same issue and ordered the aftermarket film. It came with adhesive strips on film and worked great! Over priced at $30 for 2 films but no other options unless you make them yourself.
  • GIUBOSS
    replied
    Originally posted by allstar59
    I got a call on my first HP m479 for the adf jamming. The mylar film over the slit glass is torn. I got a service\parts manual but it only shows the ADF and scanner as a unit. Is that part available separately? If not what can be used in it's place?
    Thanks for any help,
    Jim
    You could make it by cutting a sheet of transparent plastic to size, paying attention to the thickness
  • austonrush
    replied
    I don't believe HP ever made these, but you can find 3rd party aftermarket ones, that work just fine.
    Just search for HP M479 mylar strip
  • allstar59
    started a topic HP M479fdw torn mylar film on slit glass
    Jim
