LJ 4345 mfp dim display
  • Jeff M.
    • Dec 2010
    • 125
    Have a 4345 mfp with a very dim display. Works OK, but cannot adjust it bright enough to read easily. Any fix for this, or just replace entire op panel? Thanks.... Jeff M.
    • 22741
    I was hoping there would be a breakdown showing a fluorescent backlight or an inverter PWB, but no such luck. Control Panel Assy: Q3942-60102. That's your choices. =^..^=
    • Jeff M.
      • Dec 2010
      • 125
      Hi, blackcat, thanks for your reply. I believe the updated P/N Q3942-60140. Pretty pricey. Any suggestions as to the best place to get them? Appreciate your response. Merry Christmas (sorry, I'm not a very PC type of guy!)...Jeff M.
        • 22741
        TSA World - Product Catalog
        $329.00 refurbished
        • Jeff M.
          • Dec 2010
          • 125
          Thanks.... Jeff M.
          • prntrfxr
            • 1637
            I agree with Blackcat. There is no way to adjust the control panel. The only thing I know is the touchpad can be calibrated but I believe that is only with the M4345mfp not the 4345mfp. In either case, this adjusts the touchpad not the darkness of the characters. So your only recourse is to replace it.
            Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
            • Jeff M.
              • Dec 2010
              • 125
              Thanks, guys. Now let's see if they want to spring for a new op panel. Happy New Year! Regards... Jeff M.
