I replaced the laser unit on this hp LaserJet 1200 which was working but noisey. I put it back together and now the orange lower left led is blinking. The motor goes thru rotation. Secondary code is "General Fatal Error" all lights blink. All sensor flags are fine, paper, toner all is well Not sure wtf I did. any help is appreciated!
hp LJ-1200 lower left orange light blinks
New laser or used (maybe good)? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Just Manuals | The Internet's largest selection of manuals | Instant Downloads
Paul@justmanuals.comComment
Why did you replace laser unit? This laser unit has always problem with noisy polygon motor. Few times I try dissembling polygon motor mirror and put some oil in there but no successful for longer time. Only replace laser unit or polygon motor. You should check all connections,laser tape and Sensor Synchronization. I ve got this error when a I lost drum unit ground pinI ve got fever: My English isn`t good, so please please forgive me any mistakes.Comment
