Hp 4000/4100
  • Tom
    • 340
    Hp 4000/4100
    Hey all, I have a lot of these in the field , & have decided to start rebuilding the fusers myself due to cost concerns. I ordered a few of the fuser films, but sometimes it doesnt seem to work. About half of the time, the film doesn't want to turn freely, which causes fuser jams. It seems like a pretty simple design, so I must be missing something. Any comments?
    • 22850
    Re: Hp 4000/4100
    Are you cleaning off all the sleeve lubricant, and applying new sleeve lubricant? Do you replace the pressure roller at the same time? How about the pressure roller bushings?
    I've had 100% success on rebuilding HP fusers, but I record the count, any errors, and quality issues, then stuff the documentation into the box. When rebuilding, I've got a good history of each unit.
    • prntrfxr
      • 1637
      Re: Hp 4000/4100
      Can't use just any lubricant. Better to use OEM sleeves.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • Tom
        • 340
        Re: Hp 4000/4100
        Thanks for the comments. No, I haven't been replacing the LFRs, they seemed in perfect condition. As for the grease, I've tried different kinds, even light katun lube oil, didn't seem to make a difference, These are afteremarket sleeves, though. Just weird that a new sleeve will work in one fuser I'm rebuilding, but not another.
          • 22850
          Re: Hp 4000/4100
          Use Uniflor:
          Listing S4800
          This is the right stuff. I would not use anything else. =^..^=
