HP Color LaserJet 5550 Printer series
  • igor
    • Mar 2025
    Hello
    I have a problem with this machine, when I print configuration page it prints ok, when I print word file (text) it prints ok, BUT when I print a picture or *.pdf file the page that the printer prints is white, can you please help me to solute the problem ?
  • JustManuals
    • Jan 2006
    • 9919
    Re: HP Color LaserJet 5550 Printer series
    Paul@justmanuals.com
    • Wild Bill
      • Jul 2005
      • 774
      Are you saying it is blank? No Image?
      Izzy
      • igor
        no, i am saying that the page is coming white whan i am sending to print picture of pdf file
        • Wild Bill
          • Jul 2005
          • 774
          You make NO SENSE!
          Izzy
          • igor
            You make NO SENSE!
            if there was somthing that i whold know then i whont ask for help.
            other whords, if the file is big then the page is coming out white.
            • Rob Sandberg
              • 275
              Remove and reload the driver.
              • mrfixit
                Senior Technician
                • Sep 2007
                • 84
                Sounds like you need to call a technician to help you.
                • nmfaxman
                  • 1705
                  Network, USB or parallel printing?
                  What OS?
                  PCL or Postscript driver?
                  Try a different PDF program, Adobe has been getting flakey as far as printing to color boxes.
                  Try right clicking the file and print directly to printer without opening reader.
                  Make the 5550 the default printer.
                  Download latest and greatest driver, but don't replace older driver.
                  Check firmware levels
                  Just some thoughts and common solutions.
                  • igor
                    I all redy dun that.
                    • igor
                      What OS?
                      os windows xp
                      pcl or postscript i didnt check
                      i tryed to print from word by puting the picture inside and there still the same risolt
                      thanks for the tips, i will test this.
                      • prntrfxr
                        • 1637
                        There have been issues with pdf files and print drivers. Delete the current print driver, reboot, and install the latest one. Update to latest firmware. Sometimes this has to be done twice for it to take. If you are not a technician and you are updating firmware, follow HP's instructions on their website EXACTLY. Failure to do it correctly will render your printer inoperable. Or save yourself the trouble and get a trained technician.
                        • mo0651
                          • 1054
                          Are you using OEM cartridges? The pages that are printing, are they just Black and white? Send a word document with color printing.
